mil on, dtc P0090, whats that?
I asked local dealer what P0090 was and he said he`d never seen it. Seems to run OK. Thanks in advance
Is dit een goede vraag?
Neal Dameron, find a new dealer:-) P0090 - Fuel Pressure Regulator 1 Control Circuit, it controls the vacuum to the fuel pressure regulator. POSSIBLE CAUSE
PRC solenoid valve malfunction
Connector or terminal malfunction
Short to ground in wiring between PRC solenoid valve terminal B and PCM terminal 95
Open circuit in wiring between main relay terminal D and PRC solenoid valve terminal A
Open circuit in wiring between PRC solenoid valve terminal B and PCM terminal 95
Short to power circuit between PRC solenoid valve terminal B and PCM terminal 95
PCM malfunction
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 14
Altijd: 4,420
