Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Vragen Bekijk alle
Replaced screen, but missing some touch sensitivity
Just replaced the screen in my iPhone 4 and while testing, I noticed that there is no touch sensitivity on the top keyboard row (QWER..).
It seems like it is a straight line horizontally without touch. Otherwise everything seems to work fine.
What kind of issue would this be?
Would it be a completely screwed up screen or maybe it's just dirty there or what? Or too much pressure?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Monte, this sounds like a digitizer malfunction. I would contact the vendor and replace it once more. It is very unlikely that this is a loose cable and dirty connector, but you do want to take a look at those as well. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Monte zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 6
Altijd: 67
