Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Vragen Bekijk alle
MagSafe Sticker / adhesive
Hi,
since my Macbook is fully disassembled I decided to clean the ports and hubs etc.
They are REALLY dirty.
I started with the MagSafe . So I disconnected the MagSafe Board from the logic board and started to rub with a Q-tip and 99% Isopropanol.
But immediately the sticker came off.
Do you know where I can find a replacement or whatever
and Q-tips are a bit too big for the USB Hub etc . Does anyone know a smaller alternative?
Is dit een goede vraag?
1 Opmerking:
Quick follow up on this question: Is there any danger using a mac without this plastic part?
door
Voeg een opmerking toe
1 Antwoord
AFAIK there is no source for small parts like that. (You could try to pick up a damaged unit from e-bay but you'd still be in the same place... removing and reapplying the insulator) If you can't put some spray/brush adhesive on it you could try some double sticky tape.
You could also custom cut an INSULATOR out of electricians tape.
If this answer is acceptable please remember to return and mark it.
Was dit antwoord nuttig?
Voeg je antwoord toe
Buco Escobar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 461
