Ga door naar hoofdinhoud
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 Vragen Bekijk alle
unit wont turn on and wont charge!
The unit wont power up by battery or by wall plug and when attached to the charger the charging light comes on for about 10 seconds then shuts off i have tryed 3 differnt chargers they all work fine on other ds lites
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
From what I am reading it seems to be in need of an electrical repair. The fuses have blown and will need to be replaced. There you tube videos that show where and what to replace as well as fuses for sell on eBay that are the proper size (0603) and current (1-amp) they are surface mounts so a certain level of soldering capability will also be needed to fix the problem.
Was dit antwoord nuttig?
Score 1
I have the same probelm with a like new DS Lite. Why do the fuses blow out? Thanks Eduardo
Voeg je antwoord toe
nanabugbaby zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 3,240
