Mother board getting hot upon reassembly.
I disassembled my PS4 controller to paint it. Reassembled correctly from every video ive watch but when I connect the battery the spot to the left of it gets hot and the controller wont cut on.
Is dit een goede vraag?
4 opmerkingen
did you check if you got any paint etc. on the logic board? Heat on a circuit board is usually caused by shorted out components. Do not use your joystick until you find the cause for the overheating, this may cause more damage.
door oldturkey03
The mother baord was no where near the painting.
door SU44K8
Found the problem, the touch pad connection wasn't good. Blew it out and wiped it off and it's ok now.
door SU44K8
My TouchPad works fine but the section of the board where the buttons go still gets pretty hot, not sure what to do
door Jalil Jelks
