using usb cable my phone keep on charging
i need to transport some files to my laptop via usb cable but my phone is not shown as connected
Is dit een goede vraag?
First of all try to make sure your USB Cable is working properly by connecting another phone . You might have a problem with the USB bridge of your phone but I would be surprised . It's probably an issue with the cable
Else thing you can do , Try to restart your computer and your phone most cases this procedure would resolve your problem
Hope I helped
Was dit antwoord nuttig?
THANKS Bassel for answering me my usb cable is new and in good condition
In order to know what's going wrong here's what you need to do
First of all , connect the USB Cable to the wall and connect your phone . If you see that your phone is charging that means both of your USB Cable and your USB phone input are working properly . Second , download your Phone model driver from internet and install it . then restart your computer . Restart your phone and try to connect it again ,if it still don't recognize your phone , try to update your computer. Sometimes updates are blocking . Try also using another computer if you can . Hope I helped
Actually sorry , I just realized that you said that when you connect your phone it keeps on charging that means your cable and your impute are working fine . All what you need to do is to install the proper driver and restarting your computer . If it still don't recognized it , you need to change your cable . It's pretty hard to explain but even if your USB cable is working fine , sometimes it leads to issues like this
Thanks a lot i will do all those precedures
here's a link of drivers http://www.driverscape.com/download/gt-i... click under the gray button ( the first one from list )
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 716
