Ga door naar hoofdinhoud
MBP 17" will not wake up from sleep
Closed the lid one evening. Opened it next morning and nothing happened. And whatever I try, nothing has happened since!
When I open the lid, the front LED is on (solid, not breathing), the fans run (quietly) and the hard drive runs (but I don't hear the heads moving).
I have removed the battery and power, left it for a day. No luck. Exactly the same. No chimes, no display, just LED, fans and (non-booting) disk.
I have used the tutorial here to remove the RAM battery as well.
Still the same.
I'm writing this question in the hope that there is another solution than a new logic board!
Any and all suggestions welcome.
Is dit een goede vraag?
Score -1
1 Opmerking
Request for clarification: If you removed the battery and power, it is no longer sleeping. This is NOT a wake from sleep issue, your MBP fails to boot. Unfortunately you can not change a Question Title in ifixit.com, so I suggest a new question. Include the info about the failure to wake as background, but that is not the issue now.
One of my machines has failed to wake from sleep for years, but it still boots up fine every morning...
If this is not the case, please let me know.
door
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
Hook it up to an external monitor to see if it is putting out a signal.
"In July 2008, NVIDIA publicly acknowledged a higher than normal failure rate for some of their graphics processors due to a packaging defect. At that same time, NVIDIA assured Apple that Mac computers with these graphics processors were not affected. However, after an Apple-led investigation, Apple has determined that some MacBook Pro computers with the NVIDIA GeForce 8600M GT graphics processor may be affected. If the NVIDIA graphics processor in your MacBook Pro has failed, or fails within three years of the original date of purchase, a repair will be done free of charge, even if your MacBook Pro is out of warranty."
Call Apple at the following number: http://www.apple.com/support/contact/pho...
I've sent in three MacBook Pros this month with this issue and Apple has repaired them all for free. Sorry I didn't see your question sooner.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
+ My girlfriend ran into this same thing with her MacBook Pro. Sorry for digging up an old question, I'm doing moderator/admin work on Answers right now.
door
Try your luck with an SMU reset. Remove power chord and battery. Press the power button for at least 5 seconds. Reassemble and keep your fingers crossed.
Score 1
1 Opmerking:
Please do this FIRST. If it is the SMU/PMU, this may work. You have probably already reset it, this will make sure. No need to leave the battery out, pressing the power on button does the same thing faster. _____________ Please add a comment if you found instructions on this site telling you to leave the battery out - please tell me where, so I can fix that issue! _________ Thanks!
door
Try this. Hold the screen down as you release the catch and let it open slowly. Open it one half inch and wait for the screen to come up then finish opening it. MacBooks and MacBook Pros of this vintage seem to share this problem.
Thanks for the advice guys. I tried all the above and lots more. Nothing helped. In the end, I took my MBP to an Apple retailer here in Belgium where I live and asked them to diagnose it.
The answer was - even though they tried to check the graphics card failure with their (Apple vendor only) software, they couldn't get any kind of startup signal and concluded the logic board was dead.
I ordered one and they gave me a price of 450 EUR +vat (way cheaper than eBay items!!). In 2 days I had it in my possession. I used the ifixit guide on this site to help me replace it (saved another 100 EUR!) and I am know writing this article on my week-old logic board :-)
i did ve the same problem, apple retailer said that mother board ve to be change, but in fact, i let it charge when the mac was running without screen till the next morning, then it was very hot , i shut it down , wait a quart hour and then the screen suddenly work again, now it s working very well, my mac book pro was not used for more than six month cause of this, can you believe it?
also i did put an external screen when i try and try to shut down and up many time , i try so much stuff .
happy to not ve change the mother board
with mac you never know
oliv
1 Opmerking:
oups just to say in my previous message i said "wait a quart hour and then the screen suddenly work again" and in fact it s "wait a quart hour then turn it on and then the screen suddenly work again"
i can say that i ve also open it take off the hard drive put it in a case of an other external autorun 250mb hard drive, empty it & put it back @ in the MBP
olivier
door
Voeg je antwoord toe
Stuart Barkley zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 2,922
