Ga door naar hoofdinhoud
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
How to remove the all bolts of thermostat
how to remove the all bolts of thermostat nissan altima 2002 3.5l.
Is dit een goede vraag?
Score -1
1 Opmerking
consueloscott1972, I am a bit confused by your question. I am wondering which bolts you are referring to.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
consueloscott1972, try this:"
Before servicing the vehicle, refer to the Precautions Section.
Drain the cooling system.
Disconnect the negative battery cable.
If equipped with an engine undercover, remove using a power tool.
Remove drive belts
Remove water drain plug on water pump side of the engine.
Disconnect lower radiator hose.
Remove engine coolant inlet and thermostat assembly.
NOTE
Do not disassemble engine coolant inlet and thermostat. Replace them as a unit, if necessary.
To install, reverse removal procedure.
NOTE
Install thermostat with jiggle valve facing upward.
Fill the cooling system.
After installation, run engine for a few minutes and check for leaks.
From here. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
consueloscott1972 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,887
