Ga door naar hoofdinhoud
De LG Dare is een CDMA-touchscreen-telefoon, uitgebracht in 2008. Het is identificeerbaar aan het modelnummer VX9700.
Why cant I get service?
Well i dropped my phone and i had service before i dropped it and then after i couldnt get service but my account is active
Is dit een goede vraag?
Score 1
1 Opmerking
Are you able to make emergency calls? (911)
door
Voeg een opmerking toe
2 Antwoorden
It sounds like the antenna connection came loose when you dropped the phone. Take the phone apart and reseat the connector, along with securing any screws used to hold the antenna in.
The guide to open the phone can be found here: LG Dare moederbord vervangen
Was dit antwoord nuttig?
Score 2
1 Opmerking:
How do u tighten the antenna
door
Het nuttigste antwoord
it could also be the antenna switch or the power amp.
how old is the phone and has the dropping leaved any marks on the phone ?
if you still have warranty and the phone has no signs of dropping i would try to let lg fix that problem.
it exists some kind of disassembly guide for that phone - but the picture quality is not very good and it's more for the experienced user
but you can take a look if you want: CLICK here
Score 2
Voeg je antwoord toe
jacob zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 2,479
