Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
Phone Dies Despite Full Charge
After about 2 years of use the phone, **with a good charge**, dies suddenly as if it has run out of charge. Can't reboot without a charger. When initially plugged in the low batter red stripe appears - then after a minuite the initial charge state appears. Have restored the OS and have done a hard reset several times. No joy. Thanks. Thoughts? Aftermarket battery about one year old.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
It sounds like you simply need to replace the battery again.
Lithium ions usually last two years however some aftermarker ones just don't last as long.
Try replacing that battery and I bet you will see a 100 percent change!
Was dit antwoord nuttig?
Voeg je antwoord toe
GPZ zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 5
Altijd: 125
