Ga door naar hoofdinhoud
The Sony Digital Projector model VPL-ES1 is a multimedia projector produced by Sony between 2003 and 2005.
6 Vragen Bekijk alle
A Corner of the Mirror in front of the lamp is damaged
Hi,
Thanks for showing internal parts of VPL-ES1. I have ES2 which is similar to ES1. Few days back its lamp stoped functioning.
I removed lamp as shown in step 2 & 3 (Sony Digital Projector VPL-ES1 Teardown).
But while removing it damaged corners of the mirror, which is in front of the lamp.
The mirror is shown in step 19 (Sony Digital Projector VPL-ES1 Teardown).
If I don't change the mirror, will the image quality affect after putting new lamp in the projector.
Local Sony enigineer says it will not affect.
But i don't to buy a new lamp and later realize that projector is not working because of broken mirror.
Please reply.
Thanks and Regards,
Rahul Borgaonkar, India
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
like always -> the dose makes the poison
depending on the size of the damage - wou will see or not see the damaged corners. but in common - optics tending to deliver unsharper details in the corners - so many problems will never be seen - and some optics are larger than the area the are reproducing - so i would trust the sony engineer and would change the lamp
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Rahul Borgaonkar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 766
