Ga door naar hoofdinhoud
De HTC Desire is de eerste smartphone in de Desire-serie ontwikkeld door HTC.
Why does the network connection break?
After switching on the phone and entering the pin code the home network cannot be found. After some time the network is found but the connection breaks after about 30 seconds. The connection to the network cannot be restored.
The same problem occurs after a reboot. I have tried another sim card of another network provider - same phenomenom.
What do you think?
Maybe it is an antenna problem?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi,
- Look at this manual:
http://www.formymobile.co.uk/desiredisas...
The GSM antenna is the small module at the pic 2. Check and clean carefully the contacts (2x).
- Check at the "Settings" - Network connection. If its - manual, change it to automatic.
- Change the network mode to GSM only.
- You can do a factory reset to resolve the problem, if it's software.
If this not help you, ask a specialist for help.
Regards.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
jacccooo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 397
