Ga door naar hoofdinhoud
The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
222 Vragen Bekijk alle
static image and colorful screen
The problem start two weeks ago, the screen started to fail but the problem it's getting more frequently, if I use my phone for 10 seconds the image get freeze, if I turn off and turn on the screen, it shows a colorful static image like old tv without signal, if I turn off the screen for a minute, when I turn it on again, the phone works well for almost ten seconds and get stuck again but is only de image, the phone continue working with the freeze or the colorful image
I read that it could be the the part "USB Port Dock Connector Mic Flex Cable" but I want to confirm before buy it
thanks in advance
Note: the second image is not mine, I use one found in a forum but it show the same problem
Is dit een goede vraag?
Score 4
2 opmerkingen:
any solutions ?
door
yes, I fixed it changing the flex usb charge port
door
Voeg een opmerking toe
4 Antwoorden
Left my Nexus 5 for about 10 minutes, took it up to check message and the screen was the same as the second picture. Tried rebooting the phone, however nothing seems to work nor does the rebooting screen comes up
Was dit antwoord nuttig?
My phone started showing that screen with low frequency, now if I keep the display on for one minute the screen show the static-y screen
I have the same issue. Looking on forums I found the problem. You need to replace the FLEX USB charge port.
I´m looking on ebay to buy one.
Have you fixed it...i have same problem...help
1 Opmerking:
door
Voeg je antwoord toe
Alexander Morales Sevilla zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 2,273
