Ga door naar hoofdinhoud
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 Vragen Bekijk alle
Vraag afgerond
MB985LL/A - MacBookPro5,3 - A1286 - 2325*
Hello, As per your guide I don't see the BT board near the hinge and DVD drive on my Macbook Pro 15" Mid 2009.
Also there is no guide on WiFi module replacement. I am having problems with WiFi connectivity and want to replace the WiFi module.
Question: In my case, is the WiFi and BT module a single unit inside the clutch cover? Also, is it possible to remove the clutch cover without removing the screen glass? What is the WiFi module part number for my laptop top? Thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
There is two different Bluetooth setups depending if you have gloss or anti-glare screen. Only the anti-glare model has the Bluetooth board mounted near the optical drive.
You are correct this model has the AirPort board sandwiched in the clutch cover.
Follow this guide MacBook Pro 15" Unibody Mid 2009 LCD Replacement which you can see is the same procedure as the older model direct instruction on how to get to the clutch cover and the AirPort board: MacBook Pro 15" Unibody Late 2008 and Early 2009 Airport Card Replacement
But before you go down this path make sure you have double checked your connections and see if you have any damage on the lid which could effect the antennas.
MacBook Pro 15" Unibody Mid 2009 LCD Afbeelding
Handleiding
Moeilijkheid:
Zeer moeilijk
2 - 3 hours
MacBook Pro 15" Unibody Late 2008 and Early 2009 Airport Card Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
30 minutes - 2 hours
Was dit antwoord nuttig?
Score 2
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 1,301
