Ga door naar hoofdinhoud
De Nokia 5800 XpressMusic is een op Symbian gebaseerde smartphone en draagbaar entertainmentapparaat van Nokia.
Water Damaged Phone Querry
my nokia 5800 xpress music got drowned in a mug of water for 3 to 7 seconds. now its not working. initially it was working a bit like its three bottom line buttons were glowing and it was able to switch on with no display. but now its not even switching on and the three bottom LEDs are also not glowing.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
When you have a water damaged phone you must do this:
- Remove the battery and don't try to switch-on it.
- Disassemble the phone and dry off the water (stay it disassembled for some hours).
- It's good to clean it with an alcohol.
- If you have a magnifying glass, check the mother board and all connectors for oxide.
If this not help you, seek help from a mobile phone technician.
Regards.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Prateek zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 522
