Ga door naar hoofdinhoud
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Vragen Bekijk alle
After home button repair, unresponsive touch screen
I replaced the home button & cable on a Sprint iPhone 4. Everything went fine, I didn't run into any obvious issues. After reassembly/connecting the battery, the phone turned on. The locked home screen appears when it's plugged in to a power source, but the home button is unresponsive and the touch screen is unresponsive. So I'm stuck, not sure what to check for on this one.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Open phone again and make sure the connections are seeded on the lcd and digitizer if they are and still unresponsive touch you have damaged it make sure you didn't crimp the digitizer cable against frame when reinstalling ..
As for the home button make sure you have the little latch pushed down or it could be just a faulty button flex
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
MargotJoniec zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 193
