Ga door naar hoofdinhoud
Repair guides and support for gas, electric, and human powered machines used to cut grass, whether push style, or ride-on.
1206 Vragen Bekijk alle
Craftsman Walk-behind Lawn Mower stops running after primed?
I have a Craftsman walk behind model 917.377962 with a solid state engine (I think it is a Tecumseh).
It will start when primed then dies. Will keep running if I keep pushing the primer.
The small gasket that the needle fits in is cracked and I can not blow air though it with the gasket in place but can blow air though when gasket is taken out.
Any help is appreciated and God Bless
Thomas
Is dit een goede vraag?
2 opmerkingen
What "small gasket that the needle fits" needle are we talking about?
door
I think it is called the seed?
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
thomas martinie, you are not getting any fuel after the prime. Check your carburetor float to make sure it works and check the needle valve to ensure that it works. Check the fuel tank and make sure that you have a vented gas cap. Check the fuel line for any kinks, pinched of areas and internal obstruction. Replace it if it looks old and weathered. If you can give us the engine make and model, we could try and find the right carburetor settings for your mower. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thank-you
It was the seed (or small gasket the needle fits into with the float) god bless
Thomas
door
Remove the gas cap and see if it runs. I have had two small engines that had defective gas caps and I drilled little holes in them and the motors worked fine after that. First remove the gas cap before drilling holes.
The mix is definitely lean. Start with the gas cap and then clean everything.
Voeg je antwoord toe
thomas martinie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 420
