Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De BlackBerry Storm is de eerste telefoon met touch screen van RIM, uitgebracht in november 2008.
Why does my screen randomly display static?
Sometimes after I'm done sending or text, or end a call, my display seems to crash and shows an unusual "static" like image. It almost looks like what happens on a TV when you switch to a channel that doesn't exist or have signal. There doesn't seem to be any pattern to when this happens, but I do notice that it happens more often when I return to my home screen. Does anyone have advice on how to fix this problem??
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Filteren op:
It turns out that this is a typical problem with the Blackberry Storm 9530. It is specifically called a snow screen, and is caused by a hardware malfunction or disconnection. To temporarily solve the problem, restart the phone by taking out the battery (see battery replacement). But in order to fix the problem for good, you should either replace the motherboard, or take it in to your service provider and have them do it for you.
Hope this helped!
Was dit antwoord nuttig?
Voeg je antwoord toe
Kye Miranda zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 19
Altijd: 942
