The touch screen is unresponsive
I keep pushing on the touch screen but nothing moves? What should I do?
Is dit een goede vraag?
The most likely problem is a loose connection on the inside.
Check the connections of the ribbons on the inside of the device. Follow the motherboard removal guide to get to the ribbons.
If this doesn't work, the digitizer may need to be replaced. However, a guide is currently not available for that. To replace the digitizer, one would follow steps similar to the screen replacement guide, but put the components in a new digitizer.
Handleiding
Moeilijkheid:
Moeilijk
15 - 25 minutes
Handleiding
Moeilijkheid:
Gemiddeld
30 - 45 minutes
Was dit antwoord nuttig?
my tablet is in a sleep mode and will not wake no matter what I do.
Tried on and off, reset button and power and up volume button at the same time and nothing changes
Mine is the same as Amos. Sleep mode . Wont wake up.
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 37
Altijd: 9,731
4 opmerkingen
It will work with A mouse
door hmrogers01 Deel
the glass is cracked will this keep it from working
It isnt working not alittle.
door Richard James Deel
my screen is cracked and the same thing happening how do I fix this
door Fantasy Anime Lover Deel
