Ga door naar hoofdinhoud
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Vragen Bekijk alle
Backlight working but screen is black
When I turn on my MacBook, I can hear the chime and I see that the backlight is working but the screen is totally black. I can see that the backlight is working because the screen is lighter than when it is off. I replaced the LCD panel, but there is no change. What could the problem be?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Try an external Monitor. If that works the video chip is fine. Than it can only be the LVDS (video signal) cable or a faulty display panel.
Jeez, we really need a FAQ section here ;-)
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
+ Ralph
door
Using an external monitor gives the same problem. Where can I get a video chip to solder onto the motherboard?
door
Video Chip replacement not DIY
Logic board repair is an art, and requires special (expensive) equipment. You could send it off to have it replaced and re-balled.
Good Luck,
N.
Voeg je antwoord toe
Mike zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 1,716
