Ga door naar hoofdinhoud
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 Vragen Bekijk alle
Vraag afgerond
galaxy s5 change screen display
Hello my girlfriend's phone just fall down and the screen is like crap.. I m thinking to buy a lcd display and replace it I saw that it's easy but I want to know something the glue that is between the screen and the mid case exist at the new original screen? If not what I have to do? Thank you
Is dit een goede vraag?
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
iliasnikolaou23, I am not sure about the "easy replacement" :-) You should have enough adhesive retained on the midframe to keep the display glued. If not, and that is what I d in some cases, add a small amount of rubber cement to the areas. I do stay away from "Gorilla Glue" as well as crazy glue. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 2
Any samsumg screen that comes as just a screen and needs glued is not original as all genuine samsung screens come with frame attached
Score 1
2 opmerkingen:
That was for the s4. I want to buy glass with display glued. That I asked if exist glue at the glass ornot
door
Good question actually. I am wondering the same thing.
door
I just did a replacement for it on my shop, is fairly easy to take the broken screen, if you carefully heat up the screen and remove it slowly, you may actually leave the original adhesive on the frame. also when pulling up, watch out for the sensor button, since the flex cable is right behind the lcd, which mean it stick to the back of it. Other than that it was simple to take out
Score 1
Here is a very good tutorial walking you through how to step-by-step replace a cracked Galaxy S5 display http://www.etradesupply.com/blog/how-to-...
Please kindly note: Samsung Galaxy S5 comes with the new water resistance performance. However, if your Galaxy S5 suffers breakage and need to be repaired, you have to be aware of some non-reusable parts that must be replaced to the new one when reassemble.
These parts are:
Galaxy S5 front housing adhesive / form tap
Galaxy S5 Bracket Cu tape
10 screws on the middle frame
3 screws on the rear housing.
Score 1
1 Opmerking:
The screws need replacement to keep the phone waterproof?
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 5,649
