Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Vragen Bekijk alle
Repair loose blue coil without soldering?
I had done a home button repair on my iPhone and now, I have a really poor cellular signal. I suspect it is the blue coil loose since it looks misaligned and I tried checking the antenna cable. WiFi and Bluetooth is strong though. I have no soldering skills so I won't bother something like jumpering it. Is there any other way?
Also, if soldering is the only way, what is the difference between soldering back the inductor and bypassing it besides the difficulty in repair?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Patrick Brooks soldering it would be the only proper way of repairing it. Some people use a circuitwriter pen like this . I find it can get to messy and is not a good repair, but some people report success with it. The difference for the DIY'er is the size of the component as well as obtaining it. It does take a lot of skill and the right tools for this repair. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Patrick Brooks zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 139
