Ga door naar hoofdinhoud
De HTC One (codenaam M7) is de vlaggenschip-smartphone van HTC uit 2013. Hij beschikt over een naadloos ontworpen unibody omlijsting van aluminium, grote dubbele speakers aan de voorzijde en een 4,7-inch 1080p-display.
Phone doesn't read SIM-card
Hello,
I have a HTC One that does recognize when you insert a SIM card, but it is unable to read the SIM-data.
When you insert a card it shows "Preparing Simcard" but doesn't show provider information and has no reception.
Is this a faulty Sim Card reader?
Is dit een goede vraag?
Score 4
1 Opmerking
my htc one no signal no imei why ?
door
Voeg een opmerking toe
5 Antwoorden
Filteren op:
Gekozen oplossing
Maybe the Antenna is broken, check the connection of the cabels and clips that go to the backcover.
MFG
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
Have you tried restoring the phone to defaults ? (don't forget to backup your data before doing this). Some Android users that I know already had this kind of problem and it seemed to be linked to a software problem. You may thy that before starting any repair !
Score 1
it didn't help. Maybe I should mention that the phone is already opened.
Is there any antenna in the backcover so the phone cant get the provider information and reception?
the sim slot seemed to be ok because every pin in the cable had contact to a sim pin.
I changed the reader and noticed it was ok. The phone reads the phone number from the SIM card but since it has still no reception it can't receive the provider information. Any solution for this?
ok go to settings then go to about phone open to operator & it should tell you who the operator is if is working properly. ihave found they take a while to process the sim signal as well.
Voeg je antwoord toe
Domsk zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 33
Altijd: 10,870
