Ga door naar hoofdinhoud
Repair guides and support for the eighth generation of Ford F-Series trucks: the F-150, F-250, F-350, and F-Super Duty.
58 Vragen Bekijk alle
How do you check on an oil leak
There is a small leak that drips off the oil pan but can't tell where it is coming from?
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
You may not have a seal leak as these trucks had bad oil pans and it could actually be the pan itself that has holes in it
Was dit antwoord nuttig?
Score 1
Jenn76, that can come from anywhere. Leaking valve cover gaskets, bad oil pan gasket etc. I suggest you steam clean your engine and inspect a bit closer. Unless you can narrow it down, anything will be a guess.
The cleanest part of that side of the engine.
Voeg je antwoord toe
Jenn76 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 484
