Ga door naar hoofdinhoud
Reparatie-informatie voor printers gemaakt door Canon.
Problem with Canon PIXMA mini260 InkJet Photo Printer?
The roller under the print head has no black stuff on it. Does that mean my printer is dead?
I have tried cleaning the system with nozzle check pattern. The ink is fine. When I print a photo off there is a line on both sides on the paper and it looks like it's from the roller beneath the print head where the ink is located. I could really use someone's help. Please?!
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
In the properties section where U find the maintenance program is there a choice that says clean bottom roller - try that - also try using a paper towel to soak up any ink that might be on the rollers and if that is the problem just run a bunch of junk pages and the lines should eventually fade away
Was dit antwoord nuttig?
Voeg je antwoord toe
Dean Yang zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 439
