Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Vragen Bekijk alle
little inductor broke off logic board, not the blue coil
hello,
2 little pieces have broke off the logic board.
They're located here
and the little one next to it
could that be the reason i can't get a signal?
keeps searching or no service..
Could it be soldered back on and if yes, what are the names of the inductors?
thanks a lot
Updated image
Is dit een goede vraag?
Score -1
4 opmerkingen
saartje de prijck, your images are a bit to blurry to properly identify your components. Any chance you can post clearer images?
door
thank you so much :)
door
0[image|344932]
is this one better?
i know but i had to resize them :/
door
Thank you for accepting my answer. Sorry, I could not see your image:-)) I added it to the original question since Comments does not allow you to add images.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
saartje de prijck, your images are a bit fuzzy:-) See if this will answer your question.
U3_RF is a RF1642 in a QFN12 package
U21_RF is a 824-2170MHZ filter in a 0402 package. It appears to be one of Murata's "Chip Multilayer LC Filters (BPF)". Something like this most likely.
c46_RF is a 6.3V 10UF 20% capacitor in a 0402 package
Yes, it is possible that these missing components are part of your problem. Hope this helps, good luck.
Was dit antwoord nuttig?
Voeg je antwoord toe
saartje de prijck zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 322
