Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
does battery replacement lose every thing on iPhone?
Is all data and apps and music lost during battery replacement?
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
The iPhone memory is non-volatile flash, which means that you won't lose data by disconnecting (or completely draining) the battery.
However, you should *still* do a full backup before attempting any repair or sending in a device for service. For non-jailbreak iPhones, the iTunes backup is very complete.
For jailbreak phones, install AppBackup from Cydia and follow its backup instructions, then backup using iTunes. If you need to restore, you'd have to re-jailbreak, install AppBackup, restore from iTunes, then restore your jailbreak apps using AppBackup's restore features.
Was dit antwoord nuttig?
Score 7
1 Opmerking:
So should I JB forst and then backup my JB with AppBackup from Cydia and then send in for battery replacement?
Or
Send in for battery replacement and then JB? I am in 10.3.3 now and need a battery rep. Thanks!!
door
I replaced the 3GS battery and lost nothing.
Score 2
AFAIK not.
So my iPhone 6 Plus is not working and If I get. New battery, would it erase everything and like would I have to download all the apps I had? Would it also erase all of my pictures that I had?
iPhone battery is replaced it will damage display
Voeg je antwoord toe
dickm zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 32
Altijd: 70,898
