Ga door naar hoofdinhoud
Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
Left Trigger Not Working, and Start Button
I opened my controller recently because of the said defects. The Left Trigger is not jammed or dirty or anything it just doesn't work. Same goes for the start button. Im thinking to replace the whole part of of the Left trigger but I don't have spare parts.
Any suggestion?
Thanks in Advance
Is dit een goede vraag?
Score -1
2 opmerkingen
ive done that and still nothin all my controller wants to do is aim on its own
door
@ronald, what exactly do you mean by "wants to do is aim on its own"? It is moving on its own at all times? Sounds like a bad analog stick.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I would suggest reading this comment from a previous question, it could be the contact points.
My left analog stick doesnt work when you press it down.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
ok, going to clean and re-solder the contact points. Is the Sensor/Switch of the LT Button same as the Analogs?
door
There is no LT button, there is only a potentiometer. It is not part of the analog module but they share a common space causing the LT trigger bracket assembly to overlap the analog contact points unlike the RT analog stick which don't overlap making that side the easy one to fix .
door
Voeg je antwoord toe
mojr31 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 7,727
