Ga door naar hoofdinhoud
Reparaties voor de meeste tabletcomputers. Vanwege hun kleine formaat en veelvuldig gebruik van lijm is reparatie van tablets iets ingewikkelder dan reparatie van laptops.
18913 Vragen Bekijk alle
How do I fix black ink infested display on Toshiba Portégé R835-P56X?
Okay so here's what happened (to my knowledge)...
Left my tablet in between my keyboard and the screen... Power napped & then a not even 3hrs later I wake up and my screen is having seizures (vertical and horizontal lines) with some black splurges. I figure someone tried to close it and applied pressure with the tablet inside. I think this is true because I believe the extraterrestrial black ink sprawling across my screen begins where the corner of my tablet was. I took off the protective guard for the display to inspect that point but it appears to be internal because the screen is not cracked. I even spritzed some windex on ye ole screen and I can still see that ink. Fortunately I'm on spring break and there are some great experts! How do I fix this without being legally robbed by Toshiba? Teach me your ways! Please! Thank you for time! ☺
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Adrian, from your very good description, it does sound like you have a broken LCD. Check this video for the disassembly. You can get a replacement at numerous places like this. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Adrian zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,414
