Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Vragen Bekijk alle
No reception after screen repair.
After repairing the display, the phone can't make connection to the cellular provider. So it's not possible to make calls or to send text messages.
Where can i find the antenna and could I unplug the connector while fixing the screen?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The antenna cable is located right at the bottom of the motherboard just under the battery if you never removed the battery shield then don't worry about this.
Have you set the time and date correctly?
Connect to wifi and it will change it for you.
Changing the display should not interfere with the cellular service
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
govraemd zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 262
