Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatie-informatie voor de iMac G4.
iMac G4 PRAM Battery
Can the PRAM battery be replaced on the motherboard of a G4 iMac?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
4 Antwoorden
Filteren op:
Gekozen oplossing
Here it is.
However, you need to unpeel and re-apply some necessary thermal paste to replace it, only if you're up to it.
Was dit antwoord nuttig?
Score 2
Yes, it uses a 3.6V battery.
After much reasearch several articles fron apple say G4 books don't (do not) use pram batteries. They use a large capasitor to store power for pram. I just yhought you guys would like to know.
Jimmyhhome
2 opmerkingen:
The first couple of times I read the question I was also thinking iBook, and you are correct that they do not have PRAM batteries. However, by my third or fourth reading, I realized he is asking about iMacs. Thanks for the info!
door Deel
I corrected it to iMac G4
door Deel
no it was an Ibook my key board was mest up and my proof reading sucks. Deleted pram trashed ical prefs. Brotherinlaw is all happy and stuff.
Thanks guys Jimmyhhome
1 Opmerking:
Once a question is answered, accept the answer that was most helpful, they will earn 30rep and you will earn 10.
door Deel
Voeg je antwoord toe
jimmyhhome zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 7,678
