Ga door naar hoofdinhoud
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Vragen Bekijk alle
Vraag afgerond
Replaced front screen and phone will not turn on.
I replaced the front glass screen with the digitizer, and followed the steps shown on the video. Everything went great and nothing was messed up, but after I went to turn it on, the phone would not turn on, so I plugged it in to the charger and all it did was make a beep every 5 to 10 seconds, but nothing came on the screen. I also tried plugging it into the the labtop and still nothing came on the screen, but the apple menu came up on the laptop, as if it was reading the iphone, and showed how much free space remains on the Iphone, and the phone still made the beep noise. Also before I replaced the cracked front screen, the phone was working fine.
Is dit een goede vraag?
Voeg een opmerking toe
5 Antwoorden
You will need to make sure the lcd cable is proporly plugged in and hasent popped out..
If all is plugged in and still nothing you could have damaged screen when installing.
You could always try old screen again see if that works
Was dit antwoord nuttig?
4 opmerkingen:
Mitch is right hard reset first
door
Have you tryed old screen..
Hard restart and restores arnt going to work just a waste of time..
Also check have you damaged any pins were you plug lcd in..
Start with old screen first see if that works
door
Try your old screen in it see does that work then you'll no if the new screen is faulty
door
Can you try the old screen?
door
You should start with a hard reset.
I tried the hard reset when the screen did not come on, and that did nothing. I also switched the sound to off and just vibrate, and all I get when I plug it into the charger is a vibrate every 5 to 10 seconds. Is that normal?
I have the exact same problem. Anyone with any solutions
I tried the old screen. It has the same problem.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 162
