Ga door naar hoofdinhoud
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 Vragen Bekijk alle
Vraag afgerond
No lights shown on power up of 24 inch 2008 iMac
iMac "Core 2 Duo" 3.06 24-Inch (Early 2008)
iMac won't power up no fans no diagnostic lights shown - not even for a few seconds when plugged in to wall outlet. Got new power supply still no response.
Not sure if AC line filter is fried - if so how can i tell- has it got caps and can it be repaired.
Also how do i identify which of the 12 pins of the power supply is ground and what volts are expected from the others.
The 20" iMac power supply is different and is shown with photos but is not enough help
Bill
Is dit een goede vraag?
2 opmerkingen
Can you give us the last three digits of your serial number so we can correctly identify which exact model you have.
door
Hi Dan
Seria : 0km
Bill
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
See what the onboard diagnostic LED's are telling you. Review this IFIXIT guide Technique: iMac Intel 24" EMC 2134 and 2211 Diagnostic LED's
Was dit antwoord nuttig?
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 317
