Ga door naar hoofdinhoud
Model M2453 or M6411 / 300, 366, or 466 MHz G3 processor
Best way to remove writing scratched in plastic
Hi! I've purchased piles of clamshells from recyclers which have "ABC School District" or similar text etched/scratched/etc. into the plastic on the top of the case. I need to remove this before re-selling the machines because recyclers are required to remove the previous identities of the machines they take in. Does anyone know a good way to do this kind of thing without making a total mess? The text itself is scratched into the plastic and pretty low-profile as-is, however I know it will look horrible if I take my Dremel to it. Anyway, just wondering if anyone has creative ideas.
Thanks!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Polish it away with toothpaste or a chromium polish? Works for scratched watch glasses.
Was dit antwoord nuttig?
Score 4
2 opmerkingen:
Thanks for the response. Does that work for deep scratches, though? The text is scratched pretty deep into the plastic. Thanks!
door
You can try removing the bulk with sanding paper and polish afterwards.
door
Replace the LCD top cases with cheap ones bought on ebay if you can find a seller that can sell you a lot.
Score 1
Voeg je antwoord toe
rdklinc zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 2,310
