Ga door naar hoofdinhoud
Repair information for the Asus F201E laptop. Released in November of 2012. Model number: F201E-KX034H.
8 Vragen Bekijk alle
Vraag afgerond
How about the size of the built-in HDD?
hey there,
i think for replacing the HDD of the Asus F201e, because it is very slow and i can´t stand this.
Now my question:
I read the Step-by-Step Guide to Replace the HDD but you don´t write a word about the size of the HDD. Is it 2.5" or 1.8"??
Thanks for supporting :-)
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
derflo, since the replacement is a Samsung 830, it is easy to determine that it is a 2.5" drive. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
My advice is that you check for all causes that could be slowing your lap, may be don't need an hdd change, sometimes even a defragment can help, os change... micro too hot, memory amount... tooo many causes.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 456
