Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Vragen Bekijk alle
Will a iPhone 5 home button fit a iPhone 5c?
Says it all in the title.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
5 Antwoorden
Het nuttigste antwoord
This is a lie! I just put an iPhone 5 home button flex in an iPhone 5c and it works perfectly....
Was dit antwoord nuttig?
Score 3
They are compatible. done it myself with no issues
Score 3
The home button itself and its gasket is the same size between the 5 and 5c as far as I can tell, as I have both in front of me now and just swapped them no problem.
There is one minor difference in the black button as the button on the 5 has a black ring surrounding the metal dot on the back and the 5c has a white ring, which makes the square on the front of the button to appear whiter than on the 5, which appears dark.
The flex cables with the button attached are definitely different though.
Score 2
1 Opmerking:
The flex cables seem to be different in shape, but not in utility. The connectors are in the same place, aren't they? I might try installing it and seeing...
door
No
2 opmerkingen:
Are you 100% sure? They look the exact same.
door
they are interchangeable
door
no,they are different
Voeg je antwoord toe
Kevin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 6,600
