Ga door naar hoofdinhoud
Released 2006, identified by model number E1705
Broken External Power Port, Dang It!
Power cable was jammed in after computer fell to floor. The stem inside port is loose and will nolonger receive power. Is this a repairable item or should I look for a good used one and transfer my hard drive? I forgot to mention, the battery is no good, so outside power is needed to run this computer.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Eldon, the DC jack is soldered to the motherboard. Follow this guide to remove the motherboard. Unsolder the old jack and replace it with a new one. The jack is available at places like this and many others. Hope this helps, good luck
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Eldon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 140
