Ga door naar hoofdinhoud
AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
65 Vragen Bekijk alle
Open L connector adapter
This tutorial is for T magsafe adapter, where I can found how to open the L adapter connector?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Aiiman Maulana, check on here and here as well and see if that is what you are looking for.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
hi, thanks for your help. That's very helpful. :)
door
Het nuttigste antwoord
The process would be so similar as to be redundant, however if you take photos and notes you can make a guide and post it.
You can find more information about repair of these by using the "20 solutions" link on the right.
If this answer is acceptable please remember to return and mark it.
Score 2
Voeg je antwoord toe
Aiiman Maulana zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 346
