Ga door naar hoofdinhoud
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Vragen Bekijk alle
What should I do w/ random GSoD?
My new MacBook Pro has given me the Grey Screen of Death almost once a day during evening work hours. I'm not doing anything unnatural, just normal web browsing and terminal use. It feels warm to the touch but nothing out of the ordinary. What should I do?
I'm under warranty so I should be covered but since it only dies after some random period of time I'm worried they'll just say "it works fine." I'm going to encode some movies for a while to see if this will cause it to happen any sooner.
Any suggestions on how to tax my computer until it dies?
UPDATE: Found an easy way to max the processor. It didn't induce my issues tho.
I have the logs showing the crashes, is that enough proof?
UPDATE: I was lucky enough to have spare RAM around. Replacing the RAM seems to have solved the problem. No crashes for a week.
Is dit een goede vraag?
Score 2
1 Opmerking
I think the logs should be enough proof.
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
I replaced my RAM with a known good set and haven't had a crash in a week.
Was dit antwoord nuttig?
Score 1
Put some movies on the hard drive and play them constantly or until it crashes. I would also extend my warranty by getting AppleCare.
you can also run the apple hardware test. http://support.apple.com/kb/ht1509
it may actually show a problem with the RAM.
i would at least set up a support request to get the Apple RAM replaced (if it was Apple RAM) and document the issue.
if it randomly starts to kernel panic (i assume that's what you're calling "grey screen of death"), you can take it to an apple store to request diagnostics be run. the service diagnostic is very thorough and can catch weird problems.
hopefully it was just the RAM. :)
Kernel panics are almost always hardware related. Once in awhile they come from poorly written software, but you were right to replace the RAM.
Apple is also pretty good about helping you diagnose these problems. If you are convenient to an Apple Store, make an appointment with a genius and they'll put it through its paces to see what's causing the problem.
Another tool I'd strongly suggest for your arsenal is Tech Tools. A copy comes with AppleCare or you can buy the Pro version. (If you already have AppleCare but lost the CD, you can download it here by entering the serial number of your machine: https://support.apple.com/techtooldeluxe...)
Voeg je antwoord toe
Chris Cline zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 3,493
