Ga door naar hoofdinhoud
Reparatie-informatie voor de Bose QuietComfort 2 akoestische noise-cancelling hoofdtelefoon. Uitgebracht in 2003. Modelnummer: QC2.
How to fix when battery corroded
Battery corroded in my Bose Quietcomfort 2 and now they won't work. Called Bose, no help. Attempted to clean the connectors, still won't work. Any suggestions, please help!!!
Is dit een goede vraag?
Score 6
2 opmerkingen
This recommendation absolutely worked for me. You must try this before you take more invasive measures.
door
The vinegar worked for me. Ive had my Bose headset quite a while and didn’t want to part with it. I cleaned with the vinegar initially a week ago without success. Tried it just now and bam—green light. Thank you.
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
My favorite method to fix this is using a q-tip with baking soda and water. I usually just moisten the q-tip and then dip it in the baking soda then i scrub away the battery acid.
Was dit antwoord nuttig?
Score 7
5 opmerkingen:
I'm sorry. What is a q-tip with baking soda and water? Thanks!
door
Thank You. I tried the alcohol Q-tips and it cleaned the mess but no contact was made. I used the Q-tip with baking soda and it worked .
door
It worked. Thank you
door
q-tip and white vinegar worked for me.
door
I also used the Q-tip with baking soda and it worked. Thanks for posting this!
door
Vinegar is supposed to remove alkaline battery corrosion. I used a q-tip and vinegar to restore my Bose QC2s, and then was careful to never store them with the battery inside. Unfortunately, despite this, they developed the same problem again (not turning on when a good battery is inserted), and this time vinegar has not been able to make them work.
I can barely see inside, but the anode at the bottom ("-" side) looks corroded brown rather than green. Perhaps a different issue. I can't believe how fragile these super expensive headphones have been. I'll try more drastic measures to clean inside there...not much to lose at this point.
Score 7
11 opmerkingen:
it worked !! the Qtip submerged in vinegar worked. clean the battery compartment real good! Thank you thank you. I was going to return my headset but now I am going to keep it.
door
The light should turn Green..on QC 15
door
This worked for me- Bose headphones fixed. Thanks so much!!
door
Worked for me as well. thank you very much
door
this worked for me, after cleaning; insert a battery and if doesnt turn on give the headphone a little tap a few times it should turn on.
door
6 commentaren meer tonen
Hi dcar,
I would suggest to use fine sand paper and use it on the corroded metal battery holder part until you get it to look like metal again. Then use alcohol of some sort to clean it off. To avoid getting dust inside tape off any holes from battery compartment to the product before sanding.
best of luck.
Voeg je antwoord toe
dcar2004 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 35
Altijd: 27,325
