Ga door naar hoofdinhoud
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
163 Vragen Bekijk alle
Why will my Gameboy Advanced SP will not charge or turn on?
I got a GBA SP from my friends and I tried turning it on but it would not turn on. I then plugged it in to the charger. It flashed orange really quickly and then would stop charging. (Note: My OTHER friend said that the battery swells up on those things and it looks like that might be the case but I don't know how to fix that either.) If someone could help me figure that out I would be pretty happy!
Is dit een goede vraag?
Score 7
5 opmerkingen:
Same thing for me, but the battery replacement didn't work
door
I've diagnosed the problem with mine, the wiring between the charging port and the battery is somehow broken.
door
Same problem
door
Do a bridge on the F2 fuse.
door
i have that same problem
door
Voeg een opmerking toe
4 Antwoorden
Tommy the very first thing you want to do is to change your battery. Here is the guide for it. The battery is available at places like this. Hope this helps, good luck.
Was dit antwoord nuttig?
1 Opmerking:
Already did. No help
door
I think you should bye a new gameBoy Advanced SP
All you need is a new battery :)
Voeg je antwoord toe
Tommy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 12,490
