Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De T-Mobile G1 is de eerste smartphone die op de markt is gebracht met het mobiele Android-besturingssysteem. Uitgebracht in september 2008.
Why does my camera/camcorder application force close?
I have rooted G1 running the latest Cyanogen 4.2.3.1. Unfortunately, my camera/camcorder app force closes and refuses to open. I have wiped, reformated the SD, restored to stock G1 ROM, even went as far as trying another ROM thats not Cyanogen (*GASP*), but everytime it force closes. I am thinking it might be a hardware problem, but I'm not sure. Help!
Is dit een goede vraag?
Score 4
5 opmerkingen
Are you running 1.5 or 1.6?
door
I'm running CyanogenMod 4.2.5 which is based off of Donut 1.6.
door
Normally this should be asked as a comment, but I'll hold off on down-voting you since you don't have the rep for commenting.
door
sorry, i'm new, just got the code today, and don't understand this system entirely
door
try reheating the i.c around the camera,i repair phones fyi
door
Voeg een opmerking toe
5 Antwoorden
Filteren op:
Het nuttigste antwoord
This intrigued me so I went into study mode. All I can say is I do not have an answer. The cam force closes even when phone is restored to T-mob stock configuration?
Help per my reading:
1. http://twitter.com/cyanogen
2. http://wiki.cyanogenmod.com/index.php/Ma...
3. http://forum.xda-developers.com/showthre...
good luck.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
The cam does force close when the phone is restored to stock configuration. I have a feeling that its a hardware related issue at this point.
door
I'd assume then its a cyanogen bug, the latest ROM is not 100% compatible with 1.6, try a complete restore to the original rom and it should probably work.
Score 2
it sounds like it can't find the files in order to run
check and see if you accidentally moved or deleted some of the files
Score 1
update software of camera
After clicking images, images are shown reverse
Voeg je antwoord toe
Walter Galan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 7,987
