Ga door naar hoofdinhoud
Can the computer itself make a HDD go bad?
Craigslist had an immaculate iBook G4 in my area for short money and I was able to score it for my kids to use. We use it to play music and movies and games. It had a 30G HDD but everything started to act up. Programs would just close during use, and then all I could get was the startup sound, a grey screen and the Apple with the spinning wheel.
So I decided to replace the HDD with one (250G) from my old iBook G4 that worked, however the logic board was failing me.
Everything was fine for the first 3 times I used the computer, then it started to act up in the same way it did when I had the 30G HDD in there. I reset the PRAM and the PMU already.
What else do I do?
Is dit een goede vraag?
Score 1
1 Opmerking
+1 Great question! It's so helpful to know what steps to diagnose you've already tried.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Definitely not an HD issue then, you should run some diagnostics, such as the AHT, also take a look at the RAM.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Thanks, I R&R'd the RAM and it works again.
door
That's usually my second thing to check, 1) HD, 2) RAM
door
+ Ralph
door
Voeg je antwoord toe
040304 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 940
