Ga door naar hoofdinhoud
The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
221 Vragen Bekijk alle
Can Nexus 5 use battery from LG G2?
Hello,
Nexus 5 and LG G2 are very similar. There is a good chance their batteries are interchangeable.
If so, that would make it a cheap upgrade to 3000mAh for Nexus 5.
Thank you,
Sergey
Is dit een goede vraag?
Score 1
1 Opmerking
This question was migrated from http://meta.ifixit.com/Answers.
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Hi Sergey, thanks for the tip! I looked into it a bit, and it looks like the batteries have incompatible connections.
From xda-developers forum, the LG G2's battery has its connection on the top left of the battery:
From our teardown, the Nexus 5 battery connection is on the top right:
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Connector is easily moddable. But the real issue is that BL-T7 is 7mm longer - won't fit anyhow. Thank you!
door
how about the lg g flex battery? looks like the connector is on the same side as the nexus 5 battery...
http://www.servimg.com/image_preview.php...
Score 1
Are you aware of any batteries that may be suitable for an upgrade?
Would someone tell us the dimensions of the nexus 5 battery and the dimensions of LG G2 battery?
1 Opmerking:
Voeg je antwoord toe
Sergey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 17,914
