Ga door naar hoofdinhoud
De Apple Magic Mouse is een multi-touch muis die is geproduceerd en verkocht door Apple Inc. De muis werd voor het eerst aangekondigd en verkocht op 20 oktober 2009.
How can I make the Apple Magic Mouse work again?
Help! I dropped my Apple Magic Mouse and it doesn't work anymore. Does anyone know how to repair it? Appreciate your advice.
Is dit een goede vraag?
3 opmerkingen
What's it doing? Any light?
door
Thanks for your replies.
There's no external damage. The light doesn't go on when I flick the switch. I've checked the batteries and they're correctly positioned. They also still work (in another device). I bought this Mouse just two months ago in a place far from where I am now so no chance to go back and ask for a replacement. Pity really. It wasn't even a high fall - the Mouse fell from a shelf just 9 inches above a wooden floor.
Last attempt: has anyone tried fixing a Magic Mouse?
door
I have exact same problem
but my mouse does not fall
simply became incorporated
i can't back and replace my mouse too
help please
door
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
If there was no external damage , take it and your reciept to where you bought it and request replacement. Otherwise change the batteries , making sure they are in the right direction. If that doesn't work it's time to buy a new mouse.
Was dit antwoord nuttig?
Score 3
You may also have to add small pieces of aluminum foil on the negative side of the batteries. It worked for me.
Score 2
1 Opmerking:
Yey! worked!
door
The aluminum foil also worked for me. Thanks a lot !!
WOW. I really didn't think that could help but great advice!
Thank you ever so much Jing Cao for posting question and to Denis Hachey for a resolution to problem. ;)
Regards, Paul
My mouse suddenly stopped work. The batteries are new but the green light does not turn on and does not work. Is there a way to fix it. I appreciate your assistance. Maria
Voeg je antwoord toe
Jing Cao zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 11,418
