Ga door naar hoofdinhoud
Model A1236 / 4 or 8 GB capacity
134 Vragen Bekijk alle
Vraag afgerond
Determine issue: display or board?
Hello, I will try to be as specific as I can.
The main question: Whether I only have a bad display, or if the logic bad could be the issue.
Issue: So, I bought a broken ipod for repair and it works perfectly fine. I can access it through itunes, scroll around and play music. HOWEVER the display is just not there.
I have tried resets and restores multiple times. I took it apart and noticed some corrosion probably from water damage. I tried cleaning it with 91% alcohol and it didn't seem to help although it looks cleaner. Re-tested and same thing, plays music, but no display. Also the board does beep occasionally, and I'm not sure what that means.
So would the ipod work normally without a display if the board was damaged, or does it sound like it may be just the display?
I will probably try cleaning it once more today. It's not a huge deal, I'm just not sure whether I should buy a display or just scrap it for parts.
Thanks for any insight in advance.
Update
Thanks I'll try that. I'll post an update in a week or so when I get the part.
Update
Alright so the lcd was an issue and the new one appears to work except for one thing: the backlight isn't working. Any ideas?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Drew, due to the corrosion etc the way I would start is by replacing the display. Not to expensive and cheaper than measuring the video display connector with an oscilloscope;-).
Was dit antwoord nuttig?
Score 1
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 112
