Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Vragen Bekijk alle
iPhone 5 Front camera dont work after screen replacement
Hi everyone, i did a screen replacement of my iphone 5 but after that the front camera doesn't work anymore, i tried to reseat the connector but steel not working, could i screw up the logic board? help!!!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
I have two like this and it is board damage at the very edge of the board.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
you probably damaged the front camera flex cable. they are very fragile, replace and your camera will be fine
iPhone 5 Front-Facing Camera and Sensor Cable Replacement
Score 1
1 Opmerking:
should it matter if the earpiece and the brightness adjuster still working?
door
i bought a replacement camera from ifixit as well and did the replacement, they don't work. the camera when turned on just gives a small glimpse of what it sees and then freezes, do you know what the problem is?
It seems you break the cable of front-facing camera. Can you describe more detail about the front -facing camera.
Does the back camera work? Some times if back cameras broke it won't cycle to the front camera
2 opmerkingen:
Jess do you mean damage around were the camera contacts to the motherboard?
Fire up a few pics and Jesus can compare
door
Yes--there is a row of very tiny SMD components between flex connector and board edge.
The other had damage to another tiny component on the other side of the connector. I will try to post a pic later
door
Voeg je antwoord toe
Jesus Ruiz zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 6,748
