Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Vragen Bekijk alle
Vraag afgerond
Battery charges up to 5%, then it stops charging
Hello!
I have an iphone 4 that got wet. I disassembled it to dry it and I left it for a week. By the way it was working, I thought battery got broken, so then I bought a new one.
Now when I connect the iphone when the battery is over, it charges. But when it gets to 5%, iOS automatically turns on as it should be, the battery stops charging (though the dock is connected). Then it runs out of battery, and then recharges again, iOS starts, and then battery runs out again, getting into an eternal loop.
What might be the problem? Thank you very much for your help!
Is dit een goede vraag?
1 Opmerking
I tried a solution that partly works... the iPhone battery charges when it's off!!!! When it's on, I connect the dock and it's not charging, then I power the mobile off and, nothing appears in the screen, and few hours later, I turn it on again and battery it's 100%!!!!
Probably the problem is something related to what oldturkey wrote. Though it's annoying to have the iPhone off to charge it, at least I can use it.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Marc Alama, "iphone 4 that got wet." is going to become your biggest issue. It sounds like you replaced the battery, but did not clean your logic board of any corrosion etc. I strongly suggest you clean it by disassembling your phone and use isopropyl alcohol to clean it. Then check the charging IC, coil as well as the SMD components for any obvious damage.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thank you very much for your idea, I did it, trying to focus the cleaning on the parts you said, but the problem is still the same... I'll try to do a thorough cleaning again and let's see...
At least the phone turns on so I'll try to backup all my data...
thanks anyway!!
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 4,684
