Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Vragen Bekijk alle
I get "Charging is not supported by this device" w/nothing attached
Contaminated my iPhone 3GS with a mixture of oil, sugar, soy sauce. (Korean BBQ Marinade)
Not much but just enough to cause the message "Charging is not supported by this device" when ever I wake the phone from sleep.
Everything seems to work and it will charge. The message goes away when the docking cable is attached.
What do I do as the Apple "Genius" told me I'm sol unless I want to pay full freight on a new phone.
Is dit een goede vraag?
Score 1
5 opmerkingen
Thank you markus, after a bit of scrubbing with a brush and alcohol I am alert free. No disassemble required.
door
Can you accept his answers? Then he'll get credit :)
door
hi david,
great that it worked for you
²chris - yeah - would be a good idea - but the important part was that it worked
door
LOL, it's not just for credit, we do a lot of backend things based on "accepted" answers. When good questions like this get good answers I try to push to make sure the right answer gets accepted.
door
Ok, I liked the answer because it fit with my theory of what could be causing the problem. Technically it didn't "fix it" per say, but improved the situation to where I only get transitory messages telling me I have an unsupported device attached where before it was when ever I woke the phone from sleep. A tear-down and through cleaning would probably cure it, but I don't trust myself not to break a known good component in the process.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
here is the guide to get the logicboard out
my magic glass orb told me that there is a shorted connection around the dock connector.
serious - the fluid has shorted something in the charging part of the phone, it ould be that is outside on the contacts of the dock connector - look closely, use rubbing alcohol and a soft brush to clean that area carefully - if there is nothing on the outside, it's inside the phone - but i'm pretty shure about the dock connector
if you see something slightly white/greenish (almost likt mold) - thats it - if you are lukcy - you don't have to replace anything - but be careful whith the disassembling
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
David Nakase zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 8,578
