Everything fixed, still laptop giving 8 beeps
Recently, I got a BSOD and laptop gave 8 beeps and no display while restarting. I got it checked, GPU was fried, so I got it replaced. I'm still gettings 8 beeps. I tried using external monitor on a vga port and it works fine. Also, I've got the LCD display checked, it has no problem. It seems LCD is not being detected by the system. Please help!
Is dit een goede vraag?
Aman, have you checked the LVDS cable as well as the inverter?8 beeps is also indicative of video failure.If you are not able to get any video on the laptop LCD and the video is fine when the laptop is connected to an external monitor, we determine the issue to be that of LCD failure. How did you check the LCD?
door oldturkey03
oldturkey03, thanks for the comment. I suspect LVDS cable might be causing the problem. I'll try to check and report back.
door Aman
